No crank no start, all dash lights come on. I have changed battery, fuses and made sure all connection are tight.
Jul 6, 2021 at 11:42 AM
SQM
✓Experienced Mechanic
No crank no start can happen for few different reasons. Could be a defective starter or ignition switch. Check out this step by step guide to diagnose the issue:
The ign start relay bad in IPDM under hood, remove cover on white or tan or black fuse and relay center. replace ignition start relay with the fog lamp or rear wipers relay if possible and vehicle will start and run. The start run relay located at farthest passenger side top row relays. I believe there is five relays at the top. And four at the bottom.
Sep 19, 2021 at 3:23 PM
SQM
Yes, it is a good chance being that relay.
Here is a article on relay testing:
