No crank no start issue
185,000 MILES • 3.3L • V6 • 4WD • MANUAL
JESCOOK540
No crank no start, all dash lights come on. I have changed battery, fuses and made sure all connection are tight.
Jul 6, 2021 at 11:42 AM
SQM
  • 6,383 POSTS
No crank no start can happen for few different reasons. Could be a defective starter or ignition switch. Check out this step by step guide to diagnose the issue:
You also might find this video helpful:
https://youtu.be/dCjmRL3p4Cs
Jul 7, 2021 at 2:40 AM
JEROLD_BRYANT
The ign start relay bad in IPDM under hood, remove cover on white or tan or black fuse and relay center. replace ignition start relay with the fog lamp or rear wipers relay if possible and vehicle will start and run. The start run relay located at farthest passenger side top row relays. I believe there is five relays at the top. And four at the bottom.
Sep 19, 2021 at 3:23 PM
SQM
  • 6,383 POSTS
Yes, it is a good chance being that relay.
Here is a article on relay testing:
Sep 20, 2021 at 8:01 AM
