no start no spark?
115,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
JACK2292
The vehicle listed above came into shop blown head gasket repaired head gasket it ran for almost 30 minutes then shut off and restart it sounds like it's almost there ready to start but no. So replaced cam crank sensors checked for fuel pulse and checked scanner readings getting fuel pulse and has RPM signal. no codes on further inspection found only has spark on passenger side no spark on drive side all coils have power and if I ck power and the ground on coil plug I get a 12-volt reading when checked ground wire path. Any help or ideas would be awesome. thank you, Jack
Mar 27, 2025 at 4:23 PM
  • 55,583 POSTS
It sounds like a ground was left off or is loose. Also, could it be the timing belt has jumped a tooth or more? If the ground circuit is not closing the PCM is bad or is not getting a signal. So, you might want to try a crankshaft sensor. Let us know how it goes.
Mar 28, 2025 at 3:42 AM
JACK2292
thanks for your reply. Today I've rechecked all grounds and plugs previously replaced cam and crank sensors.
Mar 28, 2025 at 4:55 PM
  • 55,583 POSTS
I would connect a scanner to the data port and go to the prompt where you see engine RPM. Then crank the engine to see if the PCM shows the engine cranking.
This guide can help:
Also, I have seen a ignition coil short out which will cause the other coils on that bank stop working. You might want to try disconnection them one at a time to see if the system starts working.
Mar 29, 2025 at 3:33 AM
JACK2292
Yes I get rom signal I get can crank sink it sparks one time when first crank then nothing non driver side.
Mar 31, 2025 at 1:11 AM
  • 55,583 POSTS
Is the crank sensor OEM or name brand? It sounds like it is weak. Please let me know.
Mar 31, 2025 at 5:10 AM
JACK2292
thank all who replied to my question So here what happened today got to shop and had read this weekend u can unplug ether the crank sensor or cam sensors and it will cause it to fire so installed a factory crank sensor on driver's side nothing So unplugged the passenger side cam sensor and she fired right up ran for about 15 seconds and what I had thought came to best one of my mechanics had the timing off or a tensioner not set and it fired up hit a valve or something internal and died so back apart it shall come got to love Mondays thanks again for all the replies hope this helps someone who reads this if off by more than half tooth on one cam it will spark in one side but not on the side it's off.
Mar 31, 2025 at 1:03 PM
  • 55,583 POSTS
Good find, the computer can act strange when the camshaft timing is off. Let me know when you get the engine back together.
Apr 1, 2025 at 2:09 AM
