No start no crank/will not show shifter indicator?
2007 CADILLAC DEVILLE DTS
100,000 MILES • V8 • 2WD • AUTOMATIC
FREDW1975D
My car listed above doesn't start or crank, the shifter indicator does not show PRNDL. It has done this before and soon as the shifter indicator displays the car is in drive it starts right up. It did this when the battery got low from the alternator not working and I was trying to start the car.
Feb 24, 2024 at 8:01 PM
  • 110,244 POSTS
If the gear indicator is not working, the PCM/TCM doesn't know what gear the transmission is in. So, it won't do anything.
First, have you checked the condition of the battery? Is it fully charged? Do other electrical components function properly?
Also, take a look through this link. You may find it helpful.
Feb 25, 2024 at 11:02 AM
