No crank no start issue
300,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
JOSHUA ROGERS
  • 6 POSTS
I have changed the starter, changed the battery, changed the ignition switch and the neutral safety switch and I still have no start no crank. I need help I don't know what's going on.
May 30, 2022 at 3:19 AM
  • 55,808 POSTS
Is the security light flashing when you try to crank the engine over? If so, this guide can help you reset the system, also does this truck have an aftermarket alarm system on it?
https://www.2carpros.com/articles/how-to-reset-a-security-system
This guide can help us figure out what's going on also I have included the starter wiring diagrams so you can see how the system works.
There is a starter relay and fuse # f102 that need to be checked as well located in the interior fuse panel.
and
May 30, 2022 at 10:51 AM
JOSHUA ROGERS
  • 6 POSTS
The security light does not flash.
May 31, 2022 at 6:12 PM
JOSHUA ROGERS
  • 6 POSTS
And it does not have an aftermarket alarm system.
May 31, 2022 at 6:14 PM
  • 55,808 POSTS
Okay, it sounds like the starter has gone out but to be sure use a test light to check the trigger wire going to the starter. This guide can show you how and I have included the instructions on how to change the starter motor out in the diagrams below:
Jun 1, 2022 at 4:10 AM
JOSHUA ROGERS
  • 6 POSTS
It has a new starter on it. I put one on a couple weeks ago, it worked for like 1 week and then all of the sudden I have no start no crank again.
Jun 1, 2022 at 10:22 AM
JOSHUA ROGERS
  • 6 POSTS
So, I checked the fuse number 101 and sure enough it was blown I swapped it out with another 30 amp fuse and it started right up.
Jun 1, 2022 at 11:24 AM
  • 55,808 POSTS
Nice work, we are here to help, please use 2CarPros anytime. Can you please leave us a rating? (copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Jun 2, 2022 at 2:17 AM
JOSHUA ROGERS
  • 6 POSTS
Thank you for all your help. I will be asking again if I need any help in the future, thanks again.
Jun 2, 2022 at 9:58 AM
