No crank no start issue
253,650 MILES
AFLERLC
I change the camshaft sensor out and the crankshaft sensor out and it will not crank.
Mar 8, 2022 at 2:48 AM
  • 110,248 POSTS
When you say no crank, do you mean the starter isn't working, or does the starter work and the engine fail to start? Also, what was the vehicle doing prior to the replacement of the sensors?
If the starter isn't engaging, take a look through this link to get started, and let me know if anything helps:
If the starter does engage, start with this link:
https://www.2carpros.com/articles/car-not-running-advanced
Let me know which description identifies the issue. This way, I'll know what to start checking first.
Mar 8, 2022 at 11:43 AM
