Car will not start or crank until I wiggle
90,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
RAMROD60
car will not start or crank until i wiggle, then will crank but will not start.
Dec 30, 2016 at 10:07 PM
HMAC300
  • 48,601 POSTS
It sounds like the fuel pump has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
This guide can help.
May 4, 2021 at 10:30 AM
BOOPERIII
replace the PCM power relay
