No start issue
156,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
CHARLES SPENCER2
Replaced intake gaskets. truck fired right up no problems drove for about 2 days no problems whatsoever. Pulled in the driveway truck just shut off like I turned the key off. No noise shudder or anything now it will crank but wont start. Changed fuel pump, filter. It will start right up if I put gas straight in the throttle body. But will not run. I'm stumped. any help is appreciated.
May 4, 2021 at 12:37 PM
  • 110,248 POSTS
Have you checked the fuel pressure to confirm it is within spec? If not, here is a link that shows how it is done:
If you look at the attachments below, they include the diagnostics for fuel system problems. Since it starts when you feed it fuel, we know it is a fuel-related issue, so I thought this may be helpful.
May 4, 2021 at 2:16 PM
