No start, has fuel, spark and compression
160,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
ARMYJIM
  • 6 POSTS
Replaced water pump, along with timing belt. I have checked timing three times. Engine is in time. Replaced fuel pump to fix no fuel problem. Replaced plugs and coil for no/low spark. Compression is 95-105 psi in dry test. Have checked all fuses and relays for operation. Engine will not start. removed fuel injector connections. Engine tries to start once disconnected.
I am at a loss!
Aug 10, 2016 at 9:52 AM
SATURNTECH9
  • 30,868 POSTS
95 psi does not sound good to me. so did the timing belt break or were you just replacing it for maintenance?
Aug 10, 2016 at 10:46 AM
ARMYJIM
  • 6 POSTS
Water pump went out, so we decided to replace it. 95 is low for compression, I believe. But, originally we thought it jumped time, and thought that might be the reason it was low. However, it did not jump time, not sure why compression is so low.
Aug 10, 2016 at 1:42 PM
SATURNTECH9
  • 30,868 POSTS
Usually the reason engines get low compression is due to valve issues.
Aug 10, 2016 at 1:44 PM
ARMYJIM
  • 6 POSTS
I thought the same thing, but if I bent a valve, I would lose compression in that cylinder. I have got pretty close to the same compression in all cylinders. I did both wet and dry tests, wet tests were in the ranges of 120-145. Still not quite high enough, but should be able to start.
Aug 10, 2016 at 11:44 PM
ARMYJIM
  • 6 POSTS
I also thought about rings, but can you blow out rings all at once?
Aug 10, 2016 at 11:46 PM
SATURNTECH9
  • 30,868 POSTS
No, all rings wont fail at once unless there was lack of oil of contamination in the oil. If it ran fine before I would really suspect engine timing I know to checked it three times. But what else did you mess with that would cause the no start?
Aug 11, 2016 at 5:25 AM
ARMYJIM
  • 6 POSTS
Nothing I can think of. I even went so far as to check and see if the key-way on the crank pulley was in place properly. I even ensured I have fuel pressure. 40 psi, I believe. Could the computer be doing something I do not know about?
Aug 11, 2016 at 6:09 AM
SATURNTECH9
  • 30,868 POSTS
The computer shouldn't be doing anything it wasn't doing before the repair.So are the timing covers still off?
Aug 11, 2016 at 10:15 AM
ARMYJIM
  • 6 POSTS
Yes they are.
Aug 11, 2016 at 10:27 AM
SATURNTECH9
  • 30,868 POSTS
Could you take some good pictures of the timing marks and post them so I can see them?If I was there with the car I would want to do the same thing.
Aug 11, 2016 at 10:42 AM
