No start due to maybe fuel relay?
BLAKEHAMAR
  • 1988 PONTIAC GRAND PRIX
  • 2.8L
  • V6
  • FWD
I have put an inline pump and a new gas tank in a 88 2.8l grand prix that I am building. It has plenty of pressure at the fuel rail. It has spark at all the plugs and I have no idea why I won't start. It just turns over and never fires
Sunday, February 1st, 2015 AT 6:57 PM
CJ MEDEVAC
  • 11,004 POSTS
GIVE IT A 2 SECOND BURST OF STARTER FLUID INTO THE THROTTLE BODY, THEN ATTEMPT A START
IF IT REALLY SPITS/ SPUTTERS/ "TRIES" TO BUST OFF (TILL THE FLUID IS BURNED OFF), YOU PROBABLY HAVE A FUEL PROBLEM (MAYBE INJECTORS OR INJECTOR RELATED?)
IF YOU SORTA GET NUTHIN'
MAYBE YOU KINDA INSTALLED THE DISTRIBUTOR WRONG?
IT'S FIRING BUT AT THE WRONG TIME
I MIGHT CAN AID YOU IN CORRECT INSTALLATION, IF YOU THINK THIS IS THE ISSUE
YOUR TURN
THE MEDIC
Sunday, February 1st, 2015 AT 7:25 PM
