No start backfire from throttle body
120,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
SHARANETTAP1
Replaced cylinder and timing belt. crank engine over no start and backfire from throttle body.
Sep 12, 2016 at 2:05 PM
SATURNTECH9
  • 30,868 POSTS
Have you rechecked to make sure the engine is timed correctly? Sounds like it is not timed correctly.
Sep 12, 2016 at 4:14 PM
SHARANETTAP1
Rechecked timing checked fuel pressure got spark got injector pulse.
Sep 12, 2016 at 11:59 PM
SATURNTECH9
  • 30,868 POSTS
So did the belt break or jump time is that the reason why you changed it? or did you you just change it for maintenance?
Sep 13, 2016 at 1:00 AM
SHARANETTAP1
ran hot got head reconditioned and changed timing belt.
Sep 13, 2016 at 2:16 AM
SATURNTECH9
  • 30,868 POSTS
Is it setting any codes? It really sounds like its out of time though from the back fire through the throttle body.
Sep 13, 2016 at 9:26 AM
