Cranks but no start i got of p1610 and p1612
190,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ANDRIN ATEM
  • 414 POSTS
I realize the immo light stays on without blinking, it just stays on, when i insert the key to the run position it goes out even when i crank the car it remains off. i got of p1610 and p1612.
Feb 14, 2020 at 7:54 PM
So you have an issue with this system. I attached the procedure for these codes. Do you have a scan tool that can run through these tests?
Unfortunately there are no tricks to try and bypass these tests so we just need to go from them.
Let me know and we can go from there. Thanks
Apr 25, 2021 at 6:55 AM
ANDRIN ATEM
  • 414 POSTS
Thanks, i will reply feed backs a soon as i go through checks per your diagram.
ANDRIN ATEM
  • 414 POSTS
Hi Kenny, i noticed they had swap the immo to L instead of A, i don't know if i am sure, but i think my car listed above uses A not L for immobilizer antenna.
ANDRIN ATEM
  • 414 POSTS
If so i think that is where the communication cuts off. please do share with me your thoughts on this.
Yeah. I would have to assume the diagram is correct so if your vehicle doesn't match this then I would think that is the cause of the no communication.
ANDRIN ATEM
  • 414 POSTS
So am going to get A immo, then put it and eport back to you how it turns out.
ANDRIN ATEM
  • 414 POSTS
Hi Kenny, i found A immo, it now blink normally once in 3 seconds, but i can' find my ECU when i scan the car. so am working the the ground wire hope that will help. But if you have any suggestions on what i should check please do let me know. thanks
I am not sure I completely understand. You are trying to use your scan tool and it is not able to communicate with the vehicle? Does the vehicle start after you replaced the immo?
ANDRIN ATEM
  • 414 POSTS
No it does not. here are the dtc i got from the ECU: p1564, p1615, p1610 and p1122. i am not sure if i have to reprogram the key again. the immo security light blinks once in 3 seconds, which i think it's an indication that it's working well.
The P1615 and 1610 are related to the replacement. I attached the info for these. The P1122 I think is a different issue so I attached the diag for that as well. However, I would run through the key process and unlocking process the other codes talk about and then see what comes back.
ANDRIN ATEM
  • 414 POSTS
Thanks Ken, it was successful! I followed all test diagrams, and i was able to understand what i was dealing, after making sure my ground wires were all in good condition. i used the autel maxisys ms908pro to reinitialize the key programming, and that was able to start the car.
ANDRIN ATEM
  • 414 POSTS
Thanks a million. it was so challenging. i have been on this car for just abut 10 days, no way to get this car started. when you came in you brought more light. i needed more information, and you brought that. so i carefully followed and understood well how it works, so i became confident i was going to get this done, and i did. I am in Cameroon, west of Africa, i am a fast and quick learner.
ANDRIN ATEM
  • 414 POSTS
Great job!
Wow! You really are a fast learner if you were able to work through this. You should be proud of yourself because many of the mechanics I work with here in the USA would not have been able to follow this as it was a complicated issue.
Great work and thanks for the update.
ANDRIN ATEM
  • 414 POSTS
Thanks for the compliment, it makes me smile and happy!
ANDRIN ATEM
  • 414 POSTS
Am glad you stood by me.
That's why we are here. Anytime you need something, please come back.
If you want to, you can leave a review at the link below. It is not at all necessary but we are trying to spread the word that we are here to help. Thanks again.
https://www.sitejabber.com/reviews/2carpros.com
