The engine cranks but does not start and the check engine light is on with code 2A9A?
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAODONNE
Vehicle will not start, engine turns.
Check engine light - engine code 2A9A.
Dec 14, 2023 at 12:24 AM
  • 110,246 POSTS
The code is specific to the inlet camshaft position sensor. Either we have a faulty sensor, or there is a short to ground, power, or an open circuit.
With that in mind, inspect the wiring and connector at the sensor. If everything appears good, chances are the sensor is faulty,
I attached the directions below for replacing the sensor. Take a look through them and let me know if you have questions.
joe
Dec 14, 2023 at 12:33 PM
