No start, backfire from top of engine
290,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
REBECCASFISHER
Already replaced camshaft sensor and crankshaft sensor. What else could be the issue?
May 10, 2021 at 8:08 AM
  • 110,248 POSTS
If you are getting a backfire through the intake, it could be a stuck or burnt valve. Also, a rich fuel mixture can cause a backfire as well. Timing is another possible cause.
Was there anything that led to this happening or did it happen all at once?
Let me know. Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/engine-backfires-while-running
May 11, 2021 at 1:18 PM
