No start and sputtering on acceleration?
240,000 MILES • 5.7L • 4WD • AUTOMATIC
CANDICE MCDONALD
Began with no power when accelerating and had to crank several times to start, then would only start with starting fluid but otherwise ran okay, I replaced the fuel pump because the fuel pressure was low and now it will only start with starting fluid, will idle okay once started, but if I push the gas pedal even lightly it starts completely sputtering then dies.
Oct 17, 2026 at 8:37 PM
  • 55,721 POSTS
When you replaced the fuel pump did you replace the fuel filter as well? Also, are there any codes? Please go over this video and guide to help us get started on fixing the problem.
https://www.youtube.com/watch?v=LBCpCWEFnTg
and
https://2carpros.com/articles/engine-cranks-excessively-before-starting/
Please let me know what you find.
Oct 18, 2026 at 8:53 AM
