Engine shut off while driving will not start
CANNON1349
  • 864 POSTS
The new chain is very tight. Like up against the damper. Is that normal?
Saturday, August 31st, 2019 AT 1:59 PM
CANNON1349
  • 864 POSTS
It's almost like the chain is too short. If I put it on with the sprockets it won't line up and the bolts get too tight. If I put the sprockets on it will be lined up perfectly without the chain.
Saturday, August 31st, 2019 AT 2:32 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,272 POSTS
Can you please shoot a quick video with your phone so we can see what's going on? That would be great. You can upload it here with your response.
Sunday, September 1st, 2019 AT 10:34 AM
CANNON1349
  • 864 POSTS
I got it on, and the bolts torqued to 20 ft lbs. Chain is pretty tight. Already getting things put together.
Sunday, September 1st, 2019 AT 10:39 AM
CANNON1349
  • 864 POSTS
Got things together and the truck still acts the same way. I rotated the engine a couple of times by hand and felt no resistance. I feel like there is a spark but no fire. Also like I said before I can hit the steering column and sometimes the lights will get brighter and it will rotate faster. Also using a jump starter.
Monday, September 2nd, 2019 AT 7:03 PM
CANNON1349
  • 864 POSTS
Leak down test revealed that all the compressed air went right out of the exhaust tail pipe.
Wednesday, September 4th, 2019 AT 5:02 PM
KEN L
  • 54,272 POSTS
It sounds like the exhaust valves are burnt.
Thursday, September 5th, 2019 AT 11:30 AM
