No start after replacing spark plugs, wires, distributor, cap and rotor
230,000 MILES • 3.0L • V6 • 4WD • MANUAL
JOEBBAD
Truck was running and starting fine. I changed spark plugs and wires distributor cap and rotor truck won't start . I pulled a spark plugs wire and used old plug and I have good spark . I jumped the fuel pump and it's running. Haven't touched anything else can't figure it out. Please help.
May 1, 2021 at 2:54 AM
JOEBBAD
I. tried spraying some carburetor cleaner in intake because still have strong spark and it doesn't even effect it . The rotor is turning if it wasn't I would think it was timing belt that's the way it sounds like turn over.
May 1, 2021 at 2:40 PM
  • 110,246 POSTS
Is it possible for you to record it cranking and upload it for me to hear? The idea that you have spark and fuel (carburetor cleaner) and it doesn't start sounds like a timing issue or a sudden compression issue.
Are you sure the wires were replaced to the correct cylinders?
May 1, 2021 at 4:19 PM
JOEBBAD
I will try to record for you.
May 3, 2021 at 6:08 PM
  • 110,246 POSTS
Hi Joe,
It sounds like a plan. Also, if you can let me know what color the spark was when trying to start it, that may help as well. You want the spark to be a snapping blue color. If it is orange or white, it may be too weak to start the engine.
May 4, 2021 at 11:56 AM
