No start
150,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
STEVEN LOTT
What color of wire on the 4 pin coil pack goes were on the plug
Oct 31, 2021 at 11:12 AM
I assume you are meaning the layout of the wiring within the connector.
If so, I am attaching this info below. Here are a couple guides that will help with this:
Also, I assume you are needing to splice a connector back onto these circuits. If so, this video is great on how to solder wires correct. I understand this is a headlight connector, but the process is the same for any connector.
https://www.youtube.com/watch?v=PxA5wczsCVo
Below is the info you requested. Thanks
Nov 2, 2021 at 11:42 PM
