yes, it ran great other than boiling out the overflow. we kept the tank full and did not allow it to get too hot while we were trying to fix the problem. first replaced thermostat, then pump, then tank. the tank fixed that problem. A few days later it began taking a few seconds longer to start then idled rough for approx one to two minutes before it evened out and ran great. It only did this on initial start up after it had sat for several hours. it was not drove for the weekend. When I went to leave for work it just cranked and would not start. It has gas, can hear fuel pump running, is sparking, belts do not look worn, oil does not smell burnt.
Aug 10, 2016 at 10:13 PM
