Engine cranks but does not start?
212,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BLAKE0326
So, I pick this car up for cheap, but it will not start, you can turn it over but will not start. I have checked the relays, fuse, fuel pump, and eco, and all is good. When you jump it off it acts like it wants to start but does not. Also, the gas gauge reads full until you try starting it then it goes to empty. Please help.
Feb 7, 2024 at 11:01 AM
  • 55,721 POSTS
It sounds like it might be out of gas. Can you tell me if it tries to start if you use starting fluid?
This guide can help us get started finding the problem:
https://www.2carpros.com/articles/car-not-running-advanced
If not let's check for spark.
https://youtu.be/baq_aEWNQ0Y?si=w50V-FGdNnGj9FAc
Let's run the codes as well, also if you want to upload a short video of the engine cranking over from under the hood I can tell if the engine is hurt or not.
Please go over these guides and get back to us.
Feb 8, 2024 at 5:49 AM
  • 55,721 POSTS
anything?
May 10, 2024 at 10:39 AM
