Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Symptoms
Not Running
No start
2005 DODGE RAM
160,000 MILES • 5.7L • V8 • 2WD
129.KEN
MEMBER
Changed fuel pump, no start.
Apr 3, 2021 at 9:02 PM
Experienced Mechanic
Good morning,
Did you verify fuel pressure when you have finished the repair?
FUEL SYSTEM PRESSURE
58 psi ± 2 psi
Do you have spark? I attached a guide for checking spark.
Check the compression as well to be sure the engine is still good.
Images (Click to enlarge)
Apr 3, 2021 at 10:39 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
