No start
2006 DODGE STRATUS
114,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
253BEAST
Car listed above is an SXT model with a 2.4L DOHC. I put in new ignition, coil pack, new cam sensor, new crankshaft sensor, new spark plugs, and new starter. I've checked fuse, I can hear the fuel pump. I charged my battery but nothing; it cranks but does not start. what do I need to do to get it started and driving?
Apr 27, 2020 at 6:15 AM
Good morning,
For a quick test, spray some carburetor cleaner into the air filter and see if it starts and shuts off.
Did you check for spark at the plugs?
I would also check the compression to be sure the valve timing is correct.
Apr 27, 2020 at 6:37 AM
