If that doesn't help, tell me if this started all at once. Also, when the starter is engaged, does the engine spin faster than normal or sound differently than it did prior to the problem?
SPONSORED LINKS
Saturday, February 23rd, 2019 AT 9:28 PM
BKINN89
MEMBER
I did valve cover gaskets and intake gasket and cleaned all the carbon build up from around the rods and everything. Put it back together have new cap and button, new wires, new plugs. And I thought the same that if I have fire and fuel it should run but nothing. That is why I am reaching out for help.
Saturday, February 23rd, 2019 AT 9:35 PM
MECHANIC
Have you actually checked for spark at the plugs? Also, are you sure there isn't a major vacuum leak at the intake?
