Was fine. Parked. Then went to start it again and ot wont. Tried 2 scanners and neither one communicating with module. Any ideas?
Aug 23, 2025 at 6:34 AM
BHAMDOC1973
MEMBER
Also battery is dead so i have a jumper box on it. Dash lights come on. Fuel gauge reading. Soon as i turn ignition on fan is kicking while ac blower is off. Radio works, blower, windows. Power sliding doors and gate not working
Aug 24, 2025 at 2:20 AM
BHAMDOC1973
MEMBER
Also thinking someone has jumped it wrong. But not sure where to look
Aug 24, 2025 at 2:28 AM
✓Experienced Mechanic
I would start with a new battery, then check the major fuses in the fuse panel under the hood. Here is a guide to help you fix it and I have included the fuse locations in the images below.
Check out the images (below). Please upload pictures or videos in your response
Image (Click to enlarge)
Aug 24, 2025 at 4:42 AM
BHAMDOC1973
MEMBER
All fuses are good. I dont hear the fuel pump. I switched the fuses and relays same thing. Is the connectors to the pump inside the pump if i wanna check it?
Aug 24, 2025 at 6:48 AM
BHAMDOC1973
MEMBER
Sprayed starting fluid in the theottle body abd it started. Am guessing its the pump cause thw fuse is good and i changed the relay with another no success. I dont hear the pump
Aug 24, 2025 at 8:54 AM
Yep, a bad fuel pump is a common failure, here is the location so you can change it out. You will need to drain the fuel tank and remove it, here is how to drain the fuel, do not try to take the tank out full of fuel, it with be very heavy.
Removed all the fuel, loosened the 4 bolts but not removed yet. Removed harness and one of the fuel line connectors. Only thing left is this one, don't wanna break it, do you know how i can get it off
Aug 25, 2025 at 4:51 AM
Can you upload an image so i can see it?
Aug 25, 2025 at 6:36 AM
BHAMDOC1973
MEMBER
I broke one side of the outside esge not sure if it matters once i install ot
Aug 25, 2025 at 6:45 AM
As long as the safety holds it should be okay. If not you might need to rig something.
Aug 25, 2025 at 10:55 AM
BHAMDOC1973
MEMBER
So changed the pump and I still couldn't hear it.Checked power and there was none on any of the wires to the pump.Moved relay with another still nothing. When I have my hand on the relay and while installing it I hear and feel the click. I removed it and jumped pins 87 and 30 and I immediately heard the pump come on, but still no crank. Checked ignition spark and there is none. So am guessing the PCM is dead? They die just like that? car was running fine and all of a sudden one day decided to stop starting. Removed the fender well to see if any PCM wires are cut or wet and I found neither. I tried to find PCM relays or fuses under the hood in same box and there was none.
Aug 30, 2025 at 4:50 AM
This can be a TIPM issue or the ignition switch, with the key in the crank and run positions check the yellow and pink/white wire coming out of the ignition switch. If they are okay chances are the TIPM has gone out. The PCM closes the trigger side of the relay by grounding it fyi. Check out the images (below). Let us know how it goes
Aug 30, 2025 at 10:44 AM
BHAMDOC1973
MEMBER
You are saying these 2 wires should have battery power at run and crank?
Aug 30, 2025 at 10:47 AM
BHAMDOC1973
MEMBER
BY THE WAY ALSO SLIDE DOORS AND WINDOWS DO NOT WORK
Aug 30, 2025 at 10:50 AM
Yellow should have power in crank only the pink/white wire should have power all the time when the key is on.
Aug 30, 2025 at 10:51 AM
BHAMDOC1973
MEMBER
I confirmed both wires have power one all the time one when cranking.
Aug 30, 2025 at 11:21 AM
Okay, that just leaves the logic inside the TIPM or the PCM is bad, but lets try something, unplug the MAF sensor to se if anything changes. Both will cause the scanner not to communicate. You can send them both in for testing.
Aug 30, 2025 at 12:11 PM
BHAMDOC1973
MEMBER
Is the TIPM easy to replace and does it need programming?
Aug 31, 2025 at 2:44 AM
Yes, it is easy and does not need programming.
Aug 31, 2025 at 10:47 AM
BHAMDOC1973
MEMBER
R
Images (Click to enlarge)
Sep 1, 2025 at 5:11 AM
I think I see corrosion on the some of the pins on the their photo do you see it as well?
Sep 2, 2025 at 1:02 PM
BHAMDOC1973
MEMBER
ya I cleaned the connectors before I installed the other box, same results unfortunately. As soon as I connected the battery I saw a fuse popped which is for the abs, looked at the old fuse box same thing, but I don't think that has anything to do with it. I still don't hear the pump and don't see the RPM needle move at all. I am guessing the PCM maybe done
Sep 4, 2025 at 6:21 AM
Have you swapped out the ASD relay? Check out the images (below). Let us know how it goes
Sep 4, 2025 at 11:45 AM
BHAMDOC1973
MEMBER
No, the used fuse box came with all the relays and fuses and they exactly the same position
Sep 4, 2025 at 11:48 AM
Gotcha, I would clear the codes, and then try to start the engine and then see which codes come up.
Sep 5, 2025 at 10:53 AM
BHAMDOC1973
MEMBER
I can't. The whole thing was about the fact that the scanner is not communicating so I cannot get into any modules
Sep 5, 2025 at 11:38 AM
Did you check the fuses?
Sep 6, 2025 at 2:34 AM
BHAMDOC1973
MEMBER
ya first thing I did, all fuses under the hood
Sep 6, 2025 at 3:27 AM
We must be missing something here, please go over this post and recheck everything that was said.
Sep 6, 2025 at 9:14 AM
BHAMDOC1973
MEMBER
It was the pcm, thanks
Sep 16, 2025 at 7:58 AM
Glad you could get it fixed, thanks for letting us know.
