my engine will not start up?
200,000 MILES • 4.3L • V6 • 2WD • MANUAL
JESSE FRAZIER
Truck will crank but won't fire.
Nov 7, 2020 at 3:11 AM
The first things we need to check are fuel, spark, and compression. Here is a guide that covers the basics:
To check for fuel we need to crank the engine and spray some starter fluid in the intake and see if it fires. If not, pull a plug and hold it against the block and crank the engine to make sure you have spark.
Lastly we need to run a compression check just to ensure that is okay.
If you don't have fuel or spark then we may have a theft issue. Is the security light on?
Let's start with this info and go from there. Thanks
Jan 25, 2021 at 3:42 AM
