Crank no start issue
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
GARY A
Turns but will not start.
Sep 20, 2020 at 9:14 AM
  • 110,248 POSTS
The first two thing I would check for is spark to the plugs and fuel to the engine. The easiest way to do this is to simply see if it starts for a couple seconds using starting fluid. If it starts and then stalls, it's a fuel related issue. If it does nothing, then it's likely ignition related.
Here is a link that you may find helpful also. Take a look through it. It discusses the most common causes of a crank no start condition.
Sep 20, 2020 at 10:05 AM
