Engine cranks but does not start?
180,000 MILES • V6 • AUTOMATIC
REEREE6969
my car cranks but doesn't turn over for starting, what could it be?
Feb 15, 2023 at 7:03 AM
  • 110,248 POSTS
In most cases, either the ignition spark to the plugs is lost, or the engine isn't getting fuel. Here is what I need you to try:
See if the engine will start if you use starter fluid. If it starts and then stalls, we will know it is a fuel-related issue. If there is no change, I need you to check for spark at the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Feb 15, 2023 at 12:37 PM
