NO START
3,215 MILES • 4 CYL • FWD • MANUAL
HABIB ADAM
  • 16 POSTS
the timing belt tears. while I am driving the engine shuts off. when I diagnose, I saw the timing belt has a tear. I replace it and when I start the car, it sound as still the belt has tear. the cam-shaft and the crank-shaft is at it position ( point).
Jun 10, 2016 at 8:15 AM
SATURNTECH9
  • 30,869 POSTS
So everything is rimmed correctly all marks line up on top dead center? Also does it start at all?
Jun 10, 2016 at 3:07 PM
HABIB ADAM
  • 16 POSTS
yes, everything is rimmed correctly. No, it does not start.
Jun 16, 2016 at 2:44 PM
SATURNTECH9
  • 30,869 POSTS
I Ment timed correctly?if so do a compression test and let me know the results.You could have bent valves from the belt breaking
Jun 16, 2016 at 3:30 PM
