NO START
HABIB ADAM
  • 2005 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 3,215 MILES
The timing belt tears. While I am driving the engine shuts off. When I diagnose, I saw the timing belt has a tear. I replace it and when I start the car, it sound as still the belt has tear. The cam-shaft and the crank-shaft is at it position ( point).
Friday, June 10th, 2016 AT 3:15 PM
SATURNTECH9
  • 30,869 POSTS
So everything is rimmed correctly all marks line up on top dead center? Also does it start at all?
Friday, June 10th, 2016 AT 10:07 PM
HABIB ADAM
  • 16 POSTS
Yes, everything is rimmed correctly. No, it does not start.
Thursday, June 16th, 2016 AT 9:44 PM
SATURNTECH9
  • 30,869 POSTS
I Ment timed correctly?If so do a compression test and let me know the results. You could have bent valves from the belt breaking
Thursday, June 16th, 2016 AT 10:30 PM
