Shut off while driving, code p1633
100,000 MILES • 4 CYL
TINA 123
Cranks, obd code p1633, car shut off while driving, Pat's proves out, new battery connections, odometer does not have dashes.
Dec 27, 2018 at 9:00 AM
  • 110,248 POSTS
Here are the diagnostics for this code. Take a look through them and let me know if you have questions.
_______
QB: DIAGNOSTIC TROUBLE CODE (DTC) P0603/P1605/P1633 - INTRODUCTION
QB: Diagnostic Trouble Code (DTC) P0603/P1605/P1633 Introduction
QB: Pinpoint Tests See: Computers and Control Systems > Pinpoint Tests > QB: Diagnostic Trouble Code (DTC) P0603/P1605/P1633 - Pinpoint Test
Note
This Pinpoint Test is intended to diagnose the following:
- Battery terminal condition
- Keep Alive Power (KAPWR) wire routing
- Harness circuit: KAPWR
- Powertrain Control Module (PCM) (12A650)
Pinpoint Test Schematics and Connectors
______________
QB: Introduction See: Computers and Control Systems > Pinpoint Tests > QB: Diagnostic Trouble Code (DTC) P0603/P1605/P1633 - Introduction
QB1 CHECK BATTERY TERMINALS
Note:If KAPWR is interrupted to the PCM (that is, when a breakout box is installed or the battery is disconnected), DTC P0603/P1605 can be generated on the first power-up.
- Inspect the battery cables for loose connections, corrosion.
Are the battery terminal connections in good condition?
- KEY OFF. Battery terminals are OK. GO to QB2
- REPAIR battery terminals as necessary.
QB2 INSPECT ENGINE COMPARTMENT FOR PROPER WIRE ROUTING
- Inspect Electronic Engine Control (EC) System wiring for proximity to ignition components or wires.
Is wiring too close to ignition components or wires?
- REROUTE as necessary.
- Engine compartment wire routing is OK. GO to QB3
QB3 CHECK KEEP ALIVE POWER (KAPWR) TO PCM
Note:Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
- Disconnect PCM.
- Measure voltage between KAPWR circuit at the PCM harness connector and ground.
- While observing digital multimeter, grasp the Electronic EC harness and wiggle, shake or bend a small section while working from the PCM to the dash panel.
Does the voltage reading indicate less than 10.5 volts?
- ISOLATE and REPAIR open circuit.
- No open in KAPWR harness circuit detected. GO to QB4
QB4 CHECK FOR REPEAT OF DTC P0603/P1605/P1633
- Reconnect PCM.
- Start engine and allow it to reach operating temperature.
- Run Key On Engine Off Self-Test.
- Retrieve Continuous Memory DTCs.
Is DTC P0603, P1605 or P1633 present?
- REPLACE the PCM.
- REPAIR other DTCs as necessary. If none, testing is complete.
___________
Let me know if this helps.
JOe
Dec 29, 2018 at 11:16 AM
BMDOUBLE
  • 1,139 POSTS
Sounds like bad battery cables to me. Is the cable insulation melted at the terminals? If so, new battery cables are needed.
Dec 30, 2018 at 2:12 PM
