No start?
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOEL1980
  • 14 POSTS
Battery is not to old brand-new starter and new safety neutral switch. Starter pinion gets stuck on flywheel.
Oct 8, 2022 at 1:38 PM
  • 110,251 POSTS
When I first read your post, I was thinking there was an issue with a relay sticking, but there isn't one.
I attached the wiring schematic below for the starter circuit, so you have a reference. Based on what I am seeing, either the ignition switch is faulty or there is a mechanical issue with the starter/flex plate. Did the original starter do the same thing?
See pic below.
Oct 9, 2022 at 10:31 AM
JOEL1980
  • 14 POSTS
Thanks for your time, dude. I was messing with the safety neutral switch a minute ago and it started. Now it won't start anymore I don't have any idea of how to adjust the safety neutral switch.
Oct 9, 2022 at 10:58 AM
  • 110,251 POSTS
It sounds like you found the issue. By chance, do you know if this has the 4L60E or the 4L80E transmission?
Also, the reverse lights work off this switch as well. If you want to make adjustments, place the parking brake on and block the wheels. With the key on/engine off, place the vehicle in reverse. Move the safety switch until the backup lights turn on and tighten it in that position. See if that will work for you.
Oct 9, 2022 at 1:03 PM
JOEL1980
  • 14 POSTS
Okay, i will do that after work. thanks, I really appreciate it.
Oct 9, 2022 at 9:52 PM
JOEL1980
  • 14 POSTS
Transmission is the 60e. I can't get the truck to start.
Oct 10, 2022 at 12:36 AM
  • 110,251 POSTS
Do you mean the starter won't engage or it does, but the engine doesn't start?
As far as adjustment, I attached the directions below. Try this and let me know if it helps.
Oct 10, 2022 at 11:59 AM
JOEL1980
  • 14 POSTS
How can I bypass it?
Oct 11, 2022 at 10:33 AM
  • 110,251 POSTS
I believe the connector has two wires to it. You can use a jumper wire between the two for testing. However, the neutral safety switch wouldn't cause the starter motor to stay engaged. If I recall, that was the original problem. Is that correct?
Oct 11, 2022 at 12:19 PM
JOEL1980
  • 14 POSTS
How can I test the neutral switch and the ignition switch does the wires from neutral switch always hot? The blue wire when I adjust reverse goes off and on but the green one always hot.
Oct 11, 2022 at 1:52 PM
JOEL1980
  • 14 POSTS
I'm really appreciate your help dude, for real.
JOEL1980
  • 14 POSTS
Okay I bypassed the neutral safety switch and nothing, no start. i removed the starter and tested good, so what now?
Oct 11, 2022 at 9:50 PM
  • 110,251 POSTS
If you want to check the ignition switch, there will be two red wires to it directly from the battery that should have power at all times. Confirm that first.
If they are good, turn the key to the start position and check the purple wire at the switch for power. It should have power only when the key is in the start position.
Have you checked the 5-amp crank fuse under the dash?
Also, I attached the schematic again and highlighted things, so you have a reference.
Let me know what you find.
Oct 12, 2022 at 10:49 AM
JOEL1980
  • 14 POSTS
Thanks in advance ..been a long week ok I'd check 2 red wires hot all the time and purple wire not power it reads .18v.
Oct 14, 2022 at 11:28 AM
JOEL1980
  • 14 POSTS
Sorry I forgot. Also purple wire has continuity with starter and frame is it supposed to do that?
Oct 14, 2022 at 11:29 AM
  • 110,251 POSTS
Yes, the purple wire will have continuity with the starter. I'm not sure what you meant above.
You said, "and purple wire not power it reads.18v." Could you explain?
Oct 14, 2022 at 3:40 PM
JOEL1980
  • 14 POSTS
Purple wire with key on reads 0.18v ..
So truck has new battery, new starter, new neutral safety switch, new ignition switch and new cylinder lock.2 red wires and the purple not hot.
Oct 14, 2022 at 4:09 PM
  • 110,251 POSTS
The purple wire should only receive 12v when the key is in the start position. Is that how you checked it? If the key is just in the on position, you won't see B+ power.
Let me know if that is how it was checked. If it wasn't, try that. If it was, considering how many things you replaced, the purple wire itself may be bad.
Oct 15, 2022 at 1:41 PM
JOEL1980
  • 14 POSTS
Hey dude, I'd try it with key on start I does get 12 v (purple wire) but why starter keep getting stuck on flex plate battery is good. starter is like 2 months old I bench test starter and it worked.
I don't know if this has to do something with my problem but when signal light is on the gauges the needle fluctuate a little.
Oct 15, 2022 at 2:52 PM
  • 110,251 POSTS
The movement of the gauge is normal when the signals are on. Is the starter doing anything? For example, does it click? Does it engage and not release from the flywheel?
The only thing that triggers the starter is the ignition switch. You replaced that, correct? Is the security light staying on or flashing?
Here is the thing: If the purple wire is getting 12v with the key in the start position, either the starter has failed, or you aren't getting a solid 12v from the black wire direct from the battery. If the starter works when you have it removed, it should work when it is in the vehicle getting the same voltages unless the engine isn't grounded.
Let me know. I need to clarify if the starter is working and getting stuck on the flywheel or if it isn't working at all.
Oct 16, 2022 at 12:00 PM
JOEL1980
  • 14 POSTS
Thanks for replying. Yes, starter engage and get stuck in flywheel. Yes, the new ignition switch and security light stays on. When checking purple wire voltage not solid start from 3 all the way to 12 sometimes stay between 9 and 11volts. thanks dude, I really appreciate it.
Oct 16, 2022 at 12:21 PM
  • 110,251 POSTS
Okay, if it is the starter getting stuck, there is a chance the starter motor may need shimmed. I thought it wasn't working at all anymore. LOL So it is a mechanical issue and not an electrical one.
When you removed the old starter, did you notice if there were shims between the starter motor and where it mounts? I looked up online to get a pic of shims and attached it below.
See pic below.
Oct 16, 2022 at 1:56 PM
JOEL1980
  • 14 POSTS
No shimms when i remove starter .but it was working good .how many shimms should I put on?
Oct 16, 2022 at 2:07 PM
  • 110,251 POSTS
If nothing was removed, then you need to do one at a time to see if that takes care of the issue. Keep in mind, they come in different thicknesses.
You should be able to get them at any parts store. Also, they are not expensive.
Let me know if that takes care of the issue.
Oct 17, 2022 at 10:25 AM
