no start
13,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
WESTRUCK
  • 55 POSTS
this pick up truck is been sitting a year. Replace distributor and crank sensor still no start. It has injector plus . Fuel pump is good. What else can I check?
Dec 19, 2019 at 11:15 AM
  • 110,248 POSTS
Are you getting spark to the plugs? I noted you replaced the distributor and crank sensor.
Take a look through this link:
Also, will it start for a couple seconds if you use starting fluid?
Dec 19, 2019 at 12:28 PM
