You will have 12 volts to the positive ignition coil terminal, the smaller terminals on the back of the alternator, and the wire that is the same color at every injector, usually dark green / orange, only for one second after turning on the ignition switch, then again only when the engine is rotating, (cranking or running). That same circuit feeds the fuel pump or pump relay. If you're expecting to see 12 volts in that circuit just with the ignition switch on, that won't happen. This is a safety circuit used on all car brands in one form or another in case a fuel line gets ruptured in a crash. Removing the 12 volts stops the fuel pump from dumping raw fuel onto the ground where it would become a fire hazard.
This circuit gets the 12 volts switched on through the automatic shutdown, (ASD) relay, and that relay is turned on by the Engine Computer when it gets signal pulses from the crankshaft position sensor and the camshaft position sensor. The fastest way to tell if the ASD relay is turning on is to observe its state during cranking, with a scanner. If it is not turning on during cranking, look under "live data" at those two sensors to see if they're listed as "yes", "present", "no", or something like that. Chrysler's DRB3 scanner lists them as "No" or "Present". When one of those signals is missing, there's probably a 75 percent chance that sensor is defective, but first inspect the wiring and connector terminals for breaks and corrosion.
If you don't have access to a scanner, use a test light on the dark green / orange wire at any injector, (or the wire that is the same color at all those places), or either small terminal on the back of the alternator. You can use a digital voltmeter too, but most of them don't respond fast enough. A test light is faster and easier to interpret. You'll see the test light turn on for one second when you turn on the ignition switch. If that is missing, we have to look in a different area. What is important is if the test light turns back on during cranking. If it does not, suspect one of the two position sensors.
Also read the diagnostic fault codes, but be aware fault codes often do not set for these two sensors just from cranking the engine. They need more time to be detected, as in when a stalled engine is coasting to a stop. For that reason, do not assume the sensor circuits are okay just because there is no fault code related to them.
Chrysler made reading fault codes yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds, leave it in "run", then watch the code numbers show up in the odometer display. You can go here to see the code definitions:
https://www.2carpros.com/trouble_codes/obd2/p0300
or I can interpret them for you.
Let me know what you find, then we'll figure out where to go next.
Aug 3, 2019 at 2:12 PM
