Cranks will not start
87,000 MILES • 5.7L • V8
GLEN1960
No fuel no spark. Vats is bypassed physically and also in the tune.Do you have a troubleshooting diagram?
Jun 16, 2020 at 4:00 AM
Good afternoon,
I attached a trouble shooting chart for you below.
I attached a wire diagram as well. Since you have a tuner, some things may not be the same.
CIRCUIT DESCRIPTION
The ignition relay supplies voltage to the following components:
EVAP emissions system
A/C clutch relay
Ignition modules/coils
Fuel injectors
Mass airflow sensor
Oxygen sensors
Transmission control solenoids
DIAGNOSTIC AIDS
If the IGN relay fails to close:
Scan data will be available
Vehicle will crank, no start
Dash indicator lights will illuminate
Jun 16, 2020 at 5:38 AM
GLEN1960
Exactly what I needed. thank you!
Jun 17, 2020 at 4:50 AM
You are welcome.
Let me know if you have any other questions.
Jun 17, 2020 at 4:55 AM
