When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? We need to check for spark. this guide can help:
Check out the diagrams (below). Please let us know what you find.
Image (Click to enlarge)
Sep 29, 2019 at 3:18 AM
MARK FONTENOT2
MEMBER
On this car what all does the battery fuse control? It has five fuses on it.
Oct 2, 2019 at 3:25 PM
✓Experienced Mechanic
Those are the first stop of the power distribution for the car. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Oct 3, 2019 at 5:45 AM
MARK FONTENOT2
MEMBER
The car was turning over but not starting i changed the big battery fuse. now it does not do anything. the light goes off while cranking. Now the key fob opens the doors and windows i guess that's good.
Oct 3, 2019 at 9:36 AM
MARK FONTENOT2
MEMBER
And the fan comes on when I turn key on, but i pulled relay it went off. let me ask you this, if fob opens doors and windows I guess that means the battery is okay in it right? Also, can you show me a picture of how the harness is hooked up to battery fuse so I can make sure I got it all right? Because it has two plugs that plug in bottom of battery fuse. Brown plugged in on left grey on right.
Oct 3, 2019 at 9:40 AM
It sounds like you reset the security system by pulling the fuse. It sounds like the battery is weak though. Let try this test:
