No start
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JMOFFET
Starter does nothing. No dash lights or sounds whatsoever.
Check battery and starter while removed: both good. I have not tried to use my multi-meter yet.
What next please?
Jun 25, 2019 at 11:49 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If nothing electrical works, confirm there is a good ground from the battery to the engine block and body, and confirm the positive cable is in good condition and tight on the starter.
Next, confirm that the fuses in pic 1 are good and there is power to the circuit. Check to confirm the 30 amp circuit breaker is good in picture 2 and there is power in that circuit.
Here are a few links you may need and find helpful, or you may already know these things.
Let me know if this happened all at once or if there were electrical issues prior to this.
Jun 26, 2019 at 1:46 PM
