HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lincoln
Continental
Engine
Symptoms
Not Running
No start
STEPHENENEWLUN
MEMBER
2001 LINCOLN CONTINENTAL
4.6L
V8
2WD
AUTOMATIC
233,000 MILES
Have fire and gas will not start.
Monday, December 23rd, 2019 AT 6:50 AM
SCGRANTURISMO
MECHANIC
The problem probably is going to be compression related if your vehicle has fuel, and spark. I would recommend doing a compression test. Here is a link to a guide below on the proper way to do a compression test:
Please go through this guide and get back to us with the results. We can go from there.
Thanks,
Alex
2CarPros
SPONSORED LINKS
Monday, December 23rd, 2019 AT 8:32 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
2001 Lincoln Continental Engine Will Not Start
My 4.6l Dohc V8 Engine Will Crank, But Not Turn Over. I Have Checked The Fuel Valve Shut Oof Switsh And It Apears To Be Okay. Can You Help...
Asked by
barendsen
2001
LINCOLN CONTINENTAL
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Let My Car Run Out Of Gas And After Putting Gas In It...
Let My Car Run Out Of Gas And After Putting Gas In It The Car Will Not Start. The Car Tries To Turn Over But Won't. Is There A Fuse, Reset...
Asked by
Anonymous
2001
LINCOLN CONTINENTAL
Cranks Will Not Start
4.6l, 136,000 Miles. Drove One Hundred Miles, City And Highway. Once, After Starting The Car After It Sat In A Parking Lot For Thirty...
Asked by
96conti
11 IMAGES
1996
LINCOLN CONTINENTAL
Will Not Start
I Have A 97 Lincoln Continental It Tries To Turn Over But Won't Start?
Asked by
Spankydank
1 IMAGE
1997
LINCOLN CONTINENTAL
Car Will Not Start Or Crank 1999 Lincoln...
Car Start When Cold But After Driving For More Than 20 Minutes Car Will Not Start Right Back Up Turn The Key All Of The Power Comes On But...
Asked by
stchris96
3 IMAGES
1999
LINCOLN CONTINENTAL
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
