no start
135,000 MILES
EMAR40
died while driving on highway, had it towed home. no spark, changed cam and crank sensors and coil pack because they were originals, still no spark, after further testing found bad coil driver, replaced ecm with correct part. now it sparks but will not start, has correct fuel pressure, but it is missing pulse on only 1 injector, will this cause a no start? or do i have multiple problems?
May 5, 2013 at 4:44 AM
new or used pcm???
did you have it flashed to your vehicle?? wont start unless this is done, assuming it is the failure
May 5, 2013 at 4:45 AM
EMAR40
this is the unit installed. Cardone Part Number: 79-7177
Application: With California emission
Built from 11/01/1995
Notes: Units are pre-programmed at the factory and ready for installation with no further programming required.
May 6, 2013 at 12:59 PM
once installed it needs to be flashed to enter your vin number.
May 7, 2013 at 9:43 AM
EMAR40
Tank you for responding,
this information is from multiple sources including a Chrysler tech and his coworkers.
Chrysler introduced Flash technology ECM’s in 1996. All CARDONE ECM’s for 1996 and 1997 Chryslers are pre-flashed with the latest calibration ready for installation. No other programming, VIN or Service Reminder Indicator (SRI) information is required.
VIN and SRI programming: Chrysler applications 1998 and later, in addition to flashing, require VIN and SRI mileage programming. This information allows the ECM to communicate with other on-board computers in the vehicle. Failure to do so may cause idling and/or drivability problems,and may set diagnostic trouble codes.
May 7, 2013 at 12:17 PM
