No start and backfiring through the exhaust
180,000 MILES • 4.3L • 6 CYL • AUTOMATIC
PCHEFSONYA
  • 31 POSTS
Backfiring through exhaust. Changed out distributor, coil pack, ignition module, crank sensor and finally the PCM. Code P1351 comes back immediately after clearing and still no start and backfires excessively through exhaust.
Mar 1, 2018 at 1:01 AM
Good afternoon.
The first thing I would do is check the compression. If the timing chain moved and the engine is out of time, it will do this.
Did it do this prior to all the repairs performed?
Mar 1, 2018 at 6:45 AM
PCHEFSONYA
  • 31 POSTS
Hi Roy,
The compression is at least 160 on each cylinder. It came in as a no start, tried everything listed above. Not sure what to try next.
Mar 1, 2018 at 7:25 AM
Okay, verify the firing order on the cap to be sure the wires are not mixed up.
Mar 1, 2018 at 8:16 AM
PCHEFSONYA
  • 31 POSTS
I have done that as well. I also get 0388 code on a long crank. Something is sending high voltage to the crank sensor.
Mar 1, 2018 at 9:31 AM
Can you verify that code number? I do not see a 388 code.
High voltage? Twelve volts from the ECM fuse 1 is the feed to the pink wire. you cannot get more than battery voltage.
Mar 1, 2018 at 10:02 AM
PCHEFSONYA
  • 31 POSTS
Are you talking about the pink wire going all the way to the coil? I am sorry I think the code is P0388, high voltage to crank sensor.
Mar 1, 2018 at 10:25 AM
I have checked Alldata and Mitchel and cannot find the 388 code.
where did you get that information?
Yes, the pink wire goes to the coil, cam and crank sensor.
Mar 1, 2018 at 10:38 AM
ALAN BARR
Take the distributor back out. Turn the rotor 180 degrees and put it back in.
Sep 14, 2022 at 4:58 AM
