Not starting after sitting all winter
358,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
PHIVAL
  • 11 POSTS
Truck has been sitting all winter. Fuel pressure 55 PSI KOEO. Has injector signal from PCM. When cranking rpm shows 330-390 RPMs. Has spark. When trying to start WOT starts for a second then shuts off. Truck was running everyday prior to this. Has new battery and plugs and wires. No codes.
Mar 28, 2021 at 12:05 AM
Good morning,
Does the theft or security light go out after about 10 seconds with the key on?
This sounds like the security system is shutting it down. I attached a guide below for you to try to see if it gets it out of the security lock.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Mar 28, 2021 at 12:36 AM
PHIVAL
  • 11 POSTS
The key is not chipped.
Mar 28, 2021 at 12:57 AM
Okay, if you spray some starter fluid in the air filter, does it start and stall?
I would also check the compression to be sure the timing chain is good. You need 140-160 pounds.
Mar 28, 2021 at 1:02 AM
PHIVAL
  • 11 POSTS
140 170
170 195
140 165
190 170
Mar 28, 2021 at 2:36 AM
Okay, that is good.
What about spraying the starter fluid in the air filter? Did it start and stall?
Mar 28, 2021 at 2:49 AM
PHIVAL
  • 11 POSTS
When i squirted fuel into throttle plate i had to step on accelerator as if it was flooded. It did not start with extra fuel being squirted into the throttle plate.
Mar 28, 2021 at 3:22 AM
Did you verify the spark by removing one of the wires and checking?
Mar 28, 2021 at 3:36 AM
PHIVAL
  • 11 POSTS
yes had a wire connected to plug from coil and grounded plug.
Mar 28, 2021 at 3:58 AM
After you shut the engine off, does the fuel pressure bleed down? Looking to see if you may have an injector leaking.
Mar 28, 2021 at 4:03 AM
PHIVAL
  • 11 POSTS
about the coil no misfire codes. It may leak down 2-3 PSI.
Mar 28, 2021 at 4:25 AM
Okay, I would remove the valve covers and make sure all the valves are moving.
Valve Rocker Arm Cover Replacement - Left
Removal Procedure
1. Remove the engine sight shield, if required.
2. Remove the Connector Position Assurance (CPA) lock.
3. Disconnect the main electrical connector (2) to the ignition coil wire harness.
4. Remove the harness clips (1).
5. Reposition the engine harness, if necessary.
6. Remove the spark plug wires from the ignition coils.
^ Twist each plug wire 1/2 turn.
^ Pull only on the boot in order to remove the wire from the ignition coil.
7. Remove the ignition coil bracket studs.
8. Remove the ignition coil bracket.
9. Remove the positive crankcase ventilation (PCV) hose.
10. Loosen the valve rocker arm cover bolts.
11. Remove the valve rocker arm cover.
12. Remove and discard the old gasket (1).
13. If required, clean and inspect the rocker arm cover.
Mar 28, 2021 at 9:41 PM
PHIVAL
  • 11 POSTS
We had a big storm so after i finished pushing snow with the loader i started back onto the truck. Tried to start it with WOT twice and it started. Try ing to figure it out. Runs the same as before. No codes. Thanks for your time.
Apr 4, 2021 at 7:21 AM
Did you check the actual fuel pressure?
Apr 4, 2021 at 9:21 AM
PHIVAL
  • 11 POSTS
Yes 59 PSI. I also bought another fuel pump gauge to check. They both had the same PSI.
Apr 4, 2021 at 11:15 AM
Then the next step is to check fuel quality. From sitting a long time, the fuel itself may be the issue.
Apr 4, 2021 at 8:37 PM
PHIVAL
  • 11 POSTS
Checked that. quality is good, no water, clean. put fuel in a open container and it burns.
Apr 4, 2021 at 9:26 PM
Okay, circling back to spark, you may have a weak spark. Did you verify battery voltage to all the coils?
Apr 4, 2021 at 9:38 PM
PHIVAL
  • 11 POSTS
No, i did not.
Apr 4, 2021 at 10:23 PM
I would verify this and get back to me with the results.
Apr 4, 2021 at 10:33 PM
PHIVAL
  • 11 POSTS
okay.
Apr 4, 2021 at 10:50 PM
