No start I've got 12psi fuel pressure?
200,000 MILES • 4.3L • 4WD • AUTOMATIC
VIPERKING75
  • 58 POSTS
1991 s10 blazer. I've got 12psi fuel pressure, compression test is good (approximately 145 on all cylinders) exhaust is clear. Fuel return line is clear. Spark is good. System seems to be flooding. Will barely start with one injector unplugged and at full throttle. Coolant temp sensor is reading proper resistance. Starting fluid kills the engine. Im at a loss right now
May 25, 2026 at 7:34 PM
  • 55,710 POSTS
Yep, it will flood like this if one of the fuel injectors is shorted or the PCM is bad due to a bad injector driver inside the PCM. Here is how to test the fuel injectors.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector/
Also, check the main engine wiring grounds, (near thermostat housing). Also, I have seen a bad MAP sensor cause this issue as well, so please check the vacuum supply to the sensor. You might want to remove it and see if it is clogged. And I would try unplugging the coolant sensor to see if that makes a difference. Please go over this guide and get back to me.
May 27, 2026 at 8:49 AM
VIPERKING75
  • 58 POSTS
Injectors are working, spray pattern isn't the best, but they are functional. Unplugging the temp sensor makes no difference. Ground to intake, engine, and body all read between 0.0-0.1 ohms of resistance. Map vacuum line is clear as well
May 27, 2026 at 9:12 AM
  • 55,710 POSTS
Did you test the injectors like in the guide? They can test different when in operation. You must test the operation not just the resistance.
May 27, 2026 at 11:30 AM
VIPERKING75
  • 58 POSTS
Yes I tested in operation. They are both working, I don't have a way to test duration of the pulses though
May 27, 2026 at 11:59 AM
  • 55,710 POSTS
Bad injectors or a bad ECM are the only things I have seen hold the injectors open like that if the ECM grounds are good. Can I ask if the spark is working correctly? Please check out this video.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
May 28, 2026 at 9:45 AM
