Code P0603, no start
23,189 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ANDRIN ATEM
  • 414 POSTS
P0603 car wont start.
Dec 2, 2020 at 3:53 PM
Good morning,
Does the engine crank over?
Can you hear the fuel pump run?
Does the tachometer move up a little when you crank the engine? Trying to see if the crank sensor is sending a signal.
Was the check engine light on prior to this issue?
I do not see P0603 listed. Can you verify the code number?
Dec 2, 2020 at 6:22 PM
ANDRIN ATEM
  • 414 POSTS
Yes, fuel pump runs well, fuel is been sent to the injectors, but injectors won't open. No pulse from injector. also have p0335, crankshaft sensor, i hope to change it again tomorrow and see if i can get a start. My worry is the p0603.
Dec 3, 2020 at 7:14 AM
