No start and codes p0303, p0128 and p0113
150,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
N MICHELLE DEARMAN
  • 5 POSTS
Okay, new parts already; crankshaft sensor,plugs,wires, distributor cap and button and battery. I stopped at a stop sign and it shut off no warning. I had to b towed home since then I've replaced parts above with no luck still doing exactly same thing. It's getting fire and fuel at least to the injectors but not sure about any farther . .Please tell me what to do now.codes on meter was p0303,p0128 and p0113.
Jun 22, 2021 at 3:32 PM
  • 110,248 POSTS
I need you to try something. See if it starts for a couple of seconds and then stalls if you use starting fluid. If it does, then we know it's a fuel-related issue.
Also, here is a link that shows the most common causes of a crank no start. Take a look through it.
Now, if it does start with starting fluid and then stall, either the fuel pressure is too low or there is no power to the fuel injectors. So, if that happens, first check for an injector pulse. Here is a link that shows how it's done:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
If that is good, then confirm fuel pressure is within spec. Here is a link that shows in general how to test fuel pressure:
If you look at the pic below, I attached the manufacturer's fuel pressure specifications.
See pic below.
Jun 22, 2021 at 4:24 PM
N MICHELLE DEARMAN
  • 5 POSTS
It does not start when you spray it with starting fluid.
Jun 24, 2021 at 6:08 PM
  • 110,248 POSTS
By chance, did you check for spark at the plugs? The codes are related to a misfire, intake air temperature sensor, and thermostat. I need you to check for ignition spark and let me know if you have it.
I suspect there is no spark because the IAT and thermostat shouldn't totally shut it down. Also, you indicated above it is getting fire and fuel. By fire, are you referring to spark? If so, it should have started with starting fluid.
Jun 25, 2021 at 12:29 PM
N MICHELLE DEARMAN
  • 5 POSTS
Yes but it's very very weak spark.
Jun 26, 2021 at 5:32 AM
  • 110,248 POSTS
We may have a faulty ignition coil. Do me a favor, take a look below at the wiring schematics. I attached the entire schematic for the powertrain management. I highlighted wires I need to be checked. There is a purple wire with a white tracer which should have power. It powers the power transistor and the coil. See if there is voltage there. Let me know what you find.
If we have good voltage, then there is a chance the distributor needs to be replaced. It isn't serviceable other than the cap.
Afterthought... Make sure the rotor is in good condition and not corroded.
Jun 26, 2021 at 1:03 PM
