crank but no spark. replace coil, distributor, ECM, and CPU
May 19, 2021 at 4:03 AM
✓Experienced Mechanic
This sounds like a classic ignition module which they had big problems with. Here is the location so you can change it out to see what happens. If you did the ignition module with the distributor please test the EEC relay here is a guide to help with the location in the diagrams below:
Images (Click to enlarge)
May 20, 2021 at 11:44 AM
BILLCOLVIN94
MEMBER
Replaced both relays and the TFI on this distributor doesn't have the three contacts at the rear and was replaced with new distributor.
May 21, 2021 at 2:29 AM
BILLCOLVIN94
MEMBER
no spark while cranking, but sparks once when cranking stops.
May 22, 2021 at 3:49 AM
Lets try the EEC relay test or replacement. please let me know.
May 23, 2021 at 4:55 AM
BILLCOLVIN94
MEMBER
already replaced.
May 23, 2021 at 6:08 AM
I have seen a fuel injector short out and cause this. can you disconnect all fuel injectors to see if the spark returns? Also disconnect all oxygen sensors as well. let me know.
May 24, 2021 at 2:53 AM
BILLCOLVIN94
MEMBER
still no spark.
May 28, 2021 at 9:34 AM
Let's check the ignition switch if one "leg of the switch is bad it will not get complete power to the ECM. here is a guide to help and the ignition switch wiring diagrams below:
