No start after engine swap
2009 MAZDA 3
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BENEFITSAL
I swapped out a 2.0 on the car listed above with another 2.0. It turns over but very sluggish. It turns about two revolutions then it stops after the second try it drains the battery by the third try it just clicks upon rotation it sounds like something is binding any help would be appreciated.
Apr 11, 2022 at 8:21 AM
Let's start with two things. First, we need to put a jump box or use another vehicle to jump this battery while cranking the engine.
This sounds like a drained battery, and we need to start with this.
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
If the vehicle still does, then after there are multiple batteries or jump boxes to boost cranking amps and it still does this then we need to find out if the engine is locking up.
We do this by draining the oil and check for metal.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
I suspect we will find something with this so let's start here and we can go from there.
Thanks
Apr 12, 2022 at 12:06 PM
BENEFITSAL
Thanks for the reply I got it to start by loosening the transmission bolts and turning the flywheel manually tighten up the bolts and gave it a try it started up.
Apr 13, 2022 at 9:06 AM
Interesting. The torque converter must have been locked against the flex plate and keeping them from turning.
Good find because if you would have continued to try and start the engine it would have damaged the converter.
Thanks for the update.
Apr 14, 2022 at 8:33 AM
