Cranks does not start
260,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HARTJEN
  • 11 POSTS
Vehicle will not start. Battery and alternator are good. Tested in the last couple of weeks. Engine turns over but will not start. I can hear what I believe is the fuel pump running when the key is turned on. Truck was running about a week ago and then suddenly would not start.
Feb 28, 2019 at 1:06 AM
JDL
  • 16,098 POSTS
Make sure battery has a full charge and connections all good. Have a helper crank it while you check for spark at the plugs. If spark everywhere, use a gage and check proper fuel pressure, also, check fuel injector pulse. Any applicable trouble codes?
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Feb 28, 2019 at 1:46 AM
HARTJEN
  • 11 POSTS
Good charge on the battery and when it was running the alternator was charging. No CEL codes. Truck did sit for a few months and needed to be jumped about a month ago to get it going again. Got some intermittent misfire codes but I checked the spark on the suspect plugs and it was good. Would they suddenly stop working? Looked good when I pulled a couple for testing. Ran and drove good for about two weeks and then the problems started up. Trying to get it smog'd (CA requirement) so I can complete registration and my daughter can use the truck. Thanks for the help.
Feb 28, 2019 at 1:53 AM
JDL
  • 16,098 POSTS
I'd have to check the basics, fuel, spark, compression. I did look at your fuel pressure spec, 60--66 psi. key on engine off. If you have that spider fuel system, that system is noted for problems. I can't be positive if that system is your problem?
Feb 28, 2019 at 2:16 AM
HARTJEN
  • 11 POSTS
I will take a look at all those things this weekend and let you know what I find out.
Feb 28, 2019 at 2:18 AM
JDL
  • 16,098 POSTS
Let us know what you find.
Feb 28, 2019 at 3:40 AM
