No start
120,000 MILES • 4.6L • V8 • AUTOMATIC
JOHN GIBSON
Security light is on for a second then goes off. but ABS and traction control light stay on but won't turn over? Battery connection seems good and tight. I need help
Sep 19, 2021 at 1:40 PM
Good morning,
The ABS light will not cause a no-start condition. That is a separate issue.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Does the engine crank over? If it does not, check the battery voltage. I attached some guides for you to follow to test the battery.
Beyond that, you would need to test for fuel pressure and spark.
Below are guides for you to follow.
Let us know if you have any other questions.
Sep 20, 2021 at 2:44 AM
