Engine cranks but does not start?
121,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
JONESJ192
My vehicle cranks over normally but will not start. I was told by a neighbor to check to see if fuel pump comes on when I cycle the ignition on which it does. We then checked to see if we were getting a spark at the plugs which we weren’t.
Sep 1, 2022 at 6:06 AM
  • 110,248 POSTS
The most common cause of spark loss is a faulty crankshaft position sensor. Take a look through this link and let me know if any of the symptoms were experienced prior to failure:
Also, if you have a live data scan tool, check for an RPM signal when cranking the engine. If there isn't one, the sensor is my first suspect.
See pic below for sensor location.
Sep 1, 2022 at 1:23 PM
