Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Equinox
Engine
Symptoms
Not Running
No start
2005 CHEVROLET EQUINOX
128,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
LUIS BARAJAS
MEMBER
1 POST
Does not start. does not have spark. I connected the scanner and I got two codes p0727 speed sensor input no signal.
Aug 1, 2017 at 4:55 PM
Experienced Mechanic
It sounds like you have a crankshaft angle sensor that has gone out. here is a guide to show you what you are in for when changing the sensor:
and
and you will need to jack the car up.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a where the sensor is in your car (below).
Cheers, Ken
Image (Click to enlarge)
Aug 3, 2017 at 5:38 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
