No start code p1320
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
KCARS
Van will not start, there is no spark. got code with my code p1320. i change the coil, still nothing. can you help me?
Oct 12, 2019 at 9:29 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
You might be having an issue with the CMP (camshaft position sensor) This would be next thing to check since you replaced coil. Here is a tutorial showing how to replace:
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
I've attached a picture below on what to check for your vehicle.Hope this helps and thanks for using 2CarPros.
Danny-
Oct 13, 2019 at 10:51 AM
